Matco's avatar
Matco
Network cuts out 3x per day (Nighthawk AX12 AX6000)
I purchased this router about a month ago as an upgrade and it performs much worse than my previous nighthawk C7000, which rarely had any issues. The new router intermittently loses network (both wired and wifi) about 3x per day. Firmware: V1.2.3.28. I paid $48 for a reset device that sequentially reboots the modem, then the router ever night hoping that would remediate the issue but I’ve seen no improvement. During these “cut-outs” I’ve verified that my modem is maintaining a signal. I’ve contacted my ISP to make sure it’s not due to network disruptions. At this point I’m not sure what to do. It’s very disappointing to spend this much money on an inferior router to my previous, cheaper router. Any insights, recommendations appreciated.
  • plemans's avatar
    what firmware is on the router?
    What actual router is it? AX6000 is a speed, not a model
    what modem/gateway do you have?
    If its cutting out 3x per day, I'm not really a trusting person of ISP phone support people. I'd hardwire a pc/laptop into the modem for a day and see if it stays stable. When both wifi and wired are dropping, its always good to check yourself as the ISP's default response is always "its not our lines"
    • Matco's avatar
      Matco
      The firmware and model are both listed in my original post. Model: RAX120 firmware: V1.2.3.28. If this were related to my ISP, the issue would presumably occur with my previous router as well. It’s safe to rule ISP out of the equation.
      • plemans's avatar
        If its safe to rule out the isp then exchange the router. or start an rma with netgear.
        but anytime you change out a modem or router, things like coax can get kinked/damaged, connectors come loose, or have a sketchy modem.
        So, no its not "safe to rule out the isp" unless you've actually ruled it out yourself.
