LGrantC
May 13, 2020Aspirant
Network does not show up on device WiFi scan
Printer is Goodcom GT6000GW https://www.gsm-printer.com/mobile-receipt-printer-3g-wireless-printer-supports-multiple-language_p19.html
When scanning for WiFi this network is not found but it is finding others. All other devices find and connect.
Are there to many networks and the Goodcom GT6000GW isn't able to scroll to see more?
Potential solution? Take the device somewhere with less signals, setup your phone hotspot with the same ssid/password as the router, connect it to that. Once its connected and setup. simply shut off the hotspot. Bring the printer back to where the primary router is and see if it connects. it should auto reconnect then.
