Dr_Ryan
Jun 13, 2020Aspirant
Network no longer visible (RAX80)
The other night I restarted my computer and then could no longer see my wifi network. My computer and the other 20 devices have been connecting fine for over a year, and I have not changed any setti...
schumaku
Jun 14, 2020Guru - Experienced User
Try to forget the wireless network config on the Windows 10 settings https://kb.netgear.com/29889/How-to-delete-a-wireless-network-profile-in-Windows-10 first, then reconnect.
- Dr_RyanJun 15, 2020Aspirant
I guess I should have said that I have done that. I have forgotten all networks and even searched the registry for any mention of my network name. I have done the network reset in Windows 10 and installed/reinstalled network adapter.
- SAM_the_GAMJun 15, 2020Luminary
I am experiencing the similar situation on one of my laptops a Lenovo Thinkpad with the capability of only receving the 2.4 Gig network. I am not sure if the loss of connectivity happened after RAX80 was upgraded to 1.0.3.88 firmware or Windows 10 was upgraged to May 2020 update build 2004. The laptop can see my neighboors wifi and not mine. I had tried upgrading the drivers but there was no update. I also disabled OFDMA for the 2.4 GIG band and turned off AX. Other devices connect just fine. I was finally able to get the Lenovo laptop back online by setting up another router.
