Oct 30, 2021Aspirant
Network segmentation and VLANs
Do the Knighthawk WiFi 6 (AXxxxx) models support network segmentation? For example, separate VLANs for the WiFi and individual ethernet ports. Sadly, this was not supported on the R7xxx line of rout...
Razor512
Oct 31, 2021Prodigy
While the controls are limited, they do offer some very basic VLAN options
I attached an image showing the options.
Razor512
Oct 31, 2021Prodigy
Wanted to also add that lower end RAX series also have the same VLAN controls as pictured in the attachment, but without the 6GHz band option.
