FURRYe38's avatar
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
  • Supports the XunYou gaming feature (for China only)
  • Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
  • Improves system stability. <Maybe a fix here for the random reboots seen on v2 units.
Security Fixes:
 Bug Fixes:
  • Fixes the issue where ACLs that exceed 128 IP addresses disappear during a firmware upgrade.
  • Various minor bug fixes.
Download Links:
RAX120/120v2: Same version for both model RAX120 series routers.
https://www.netgear.com/support/product/RAX120#download
To update your router’s firmware, follow the instructions in your router’s user manual. To find your router’s user manual, visit:
https://www.netgear.com/support/product/rax120.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
