Sep 08, 2022Guru - Experienced User
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
Supports the XunYou gaming feature (for China only)
Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
Improves system stability. <Maybe a fix...
michaelkenward
Sep 22, 2022Guru - Experienced User
mudbone wrote:
I had to do a double take on that comment. Those DOS alerts are not fake and there is supposed to be a way to suppress them if you don't want to see them. All you have to do is uncheck a box.
Most of them are. This is a well known "feature" of Netgear routers that dates back years.
Search - NETGEAR Communities – DoS attacks
Have you tried an IP lookup for them?
avtella
Sep 23, 2022Prodigy
Michael me ward is right, I have had issues with that feature for years. I always disable it has caused me issues with a lot of legitimate stuff. In my experience almost all of the supposed attacks in my logs were not actual DDOS attempts.
- mudboneOct 21, 2022Apprentice
The checkbox is named "Known DoS attacks and Port Scans". In the older version of the firmware 1.2.3.28 it was working. It stopped working in this newer version. I have always checked this checkbox because I am wanting to see what is hitting my router from the outside. I have version 1 of the RAX120 router and have already factory reset it after I saw it was not working anymore and the reset changed nothing. The firmware developer broke it and that is a bad thing. If you read the release notes you will see that they made a change to support a Chinese game. I really hope that the developer did not break this function on purpose so that the Chinese military could hack into the network without being caught. Might just be paranoia but we are not on the best of terms right now with the Chinese government.
