Sep 08, 2022Guru - Experienced User
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
Supports the XunYou gaming feature (for China only)
Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
Improves system stability. <Maybe a fix...
jkarppa
Mar 11, 2023Aspirant
Can I also get the new beta/release-candidate firmware?
Have two RAX120v2 routers. Both serials start with 6JY.
Both a are crashing/rebooting several times a day if they're in use (uptime resets). When not used at all (no wireless devices connected), no reboots. Streaming movies through Amazon FireTV triggers a crash roughly once per hour, even when using "safest" settings with only 5 GHz WiFi and no other wireless devices connected.
merkx
Mar 12, 2023Aspirant
How do we get the beta firmware for the RAX120v2? Please share.
- AliCat6935Mar 13, 2023Aspirant
if I knew id say, I was hoping someone would be able to share it from netgear etc.
- phobosptMar 15, 2023Aspirant
Hello,
Can i confirm the necessary specs to access the beta firmware that seems to address the random reboots on a RAX120v2?
My serial number start with 6K01195 and ends on 1B3
thank you
- DarrenMMar 28, 2023Sr. NETGEAR Moderator
Here is a link to a beta firmware that has fixes for the reboot issue. Please let me know if you have any other issues with this firmware https://ntgr.my.salesforce.com/sfc/p/#300000000xsV/a/8b000000lpfE/ewZuT7whqirNo5U_QG.WfrQU.h0pa5dqpbB3qz_Qi3o
