Sep 08, 2022Guru - Experienced User
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
Supports the XunYou gaming feature (for China only)
Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
Improves system stability. <Maybe a fix...
brushie_
Apr 04, 2023Aspirant
I just updated to this and had my network just cut out. Left it alone for an hour just in case it was still updating. Couldn't log into the router to check on the status of anything in my network. My networks would appear but say no internet access is available, not even wired.
After that hour I did a power cycle. Still getting the same issues. After multiple attempts, I had a factory reset. Same problem, can't login to change any router settings and getting no internet.
- FURRYe38Apr 04, 2023Guru - Experienced User
Whats the first 3 characters of the routers serial number seen on the back sticker?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What browser are you using? Try MS Edge or Firefox.
Be sure to clear out all browser caches before entering the routers web page at 192.168.1.1 after a factory reset. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
After that hour I did a power cycle. Still getting the same issues. After multiple attempts, I had a factory reset. Same problem, can't login to change any router settings and getting no internet.- brushie_Apr 04, 2023AspirantFirst three of the serial is 67T and I'm using a Motorola MB8611 I got along with the router on the same day.
Always been using Firefox on all my devices, but cleared the cache and cookies, still can't get in.
Other things I've noticed is that I can get internet access connecting directly to the modem. I also have access to my NAS while I'm connected to the router. Currently just can't get internet access from the router, and can't log into the router settings.- filthgorgerApr 04, 2023Aspirant
Hey FURRYe38,
Could I request a copy of the beta firmware for the RAX120? I hear it works well. Is the link available that provides firmware 1.2.8.43 the current iteration?
First 3 of my model number are 6JY.
