Mar 19, 2022Guru - Experienced User
New - RAX20 Firmware Version 1.0.10.110 Released
Security Fixes: 3/14/2022
Fixes security vulnerabilities
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Firmware Update Instructions
Retired_Member
Mar 24, 2022Update Breaks Advanced Tab
Updated today (2022-03-24) to Firmware Version V1.0.10.110_2.0.72 and now I cannot access the Advanced tab on the router setting page.
I had the exact same issue, i had to power off my RAX20 at the wall and restart it for the Advanced tab to work again.
No problem now.
- FURRYe38Mar 25, 2022Guru - Experienced User
Was a factory reset and setup from scratch performed after updating FW?
- Retired_MemberMar 25, 2022
FURRYe38 wrote:Was a factory reset and setup from scratch performed after updating FW?
You can't do either with automated FW update and then you're locked out of the Advanced tab with a frozen GUI, the only option in my case was to hard power off and on again.
- DeezNApr 05, 2022AspirantNighthawk app is coming up with an issue when in device manager claiming the router is offline despite it providing me with internet. Also getting the cdil-api-fail error message when I go into it on the app. Tired of troubleshooting for an hour. RAX50
- FURRYe38Apr 05, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
