Mar 19, 2022Guru - Experienced User
New - RAX20 Firmware Version 1.0.10.110 Released
Security Fixes: 3/14/2022
Fixes security vulnerabilities
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Firmware Update Instructions
Retired_Member
Mar 24, 2022Update Breaks Advanced Tab
Updated today (2022-03-24) to Firmware Version V1.0.10.110_2.0.72 and now I cannot access the Advanced tab on the router setting page.
I had the exact same issue, i had to power off my RAX20 at the wall and restart it for the Advanced tab to work again.
No problem now.
Mar 25, 2022Guru - Experienced User
Was a factory reset and setup from scratch performed after updating FW?
- Retired_MemberMar 25, 2022
FURRYe38 wrote:Was a factory reset and setup from scratch performed after updating FW?
You can't do either with automated FW update and then you're locked out of the Advanced tab with a frozen GUI, the only option in my case was to hard power off and on again.
