hd2
Jul 20, 2022Aspirant
New - RAX200 Firmware version 1.0.10.140_1.0.79 Released
Currently stuck on 1.0.5.132 due to the DNS bug with OpenVPN, but seeing 1.0.10.140_1.0.79 offered, and I can't find any user feedback on it. Release notes before updating show: Release Notes:...
Jul 20, 2022Guru - Experienced User
You can manually download it from the support site and manually install it.
Nighthawk RAX200 | Tri Band Router | NETGEAR Support
I'd make a backup in case you do want to downgrade. Then you could downgrade, factory reset, and reinstall your backup and be back where you started if it didn't work well for you.
