Apr 23, 2022Guru - Experienced User
New - RAX200 Firmware Version 1.0.6.138 Released
New Features and Enhancements:
Adds support to EU SKU for Router Analytic (RA) opt-in, opt-out feature
Removes support from China SKU for gaming VPN Funjsq
Security Fixes:
Fixes sec...
nicoimages
Apr 27, 2022Tutor
Version 1.0.6.138 breaks DNS. I had to revert to 1.0.5.132 to get everything to work again. This happens for both WiFi and direct network connections. Entering DNS servers manually into connected devices resolves the issue temporarily but is not sustainable. It looks like similar problem have been caused by previous updates but were then subsequently resolved
Apr 27, 2022Guru - Experienced User
Did you factory reset the router and setup from scratch after loading v.138?
Did you try enabling IPv6 on the router as well after v.138 was loaded?
- crjohnsonApr 27, 2022Guide
Pertaining to DNS functionality, I'm interested as well in the results of the factory reset.
Thanks in advance for following up.
