Apr 23, 2022Guru - Experienced User
New - RAX200 Firmware Version 1.0.6.138 Released
New Features and Enhancements:
Adds support to EU SKU for Router Analytic (RA) opt-in, opt-out feature
Removes support from China SKU for gaming VPN Funjsq
Security Fixes:
Fixes sec...
Apr 29, 2022Guru - Experienced User
Is the DNS issue seen if OpenVPN not used at all? Just the router and default DNS settings?
adm1r4lj wrote:
These are my findings from yesterday:
- The DNS proxy crash issue triggers on 1.0.6 when we enable OpenVPN and reboot the RAX200.
- If we enable OpenVPN on 1.0.6 and do not reboot the RAX200, the DNS issue does not trigger. Tested working fine for approx. 2hrs.
- Reverting back to 1.0.5 eliminates this bug while maintaining VPN and DNS functionality after a reboot.
Hopefully a bugfix will be made available soon.
adm1r4lj
Apr 29, 2022Star
FURRYe38 - not in our testing. When we disabled OpenVPN and rebooted the RAX200 under 1.0.6, the issue went away. When we enabled OpenVPN and rebooted, the issue resurfaced. Also if we disabled OpenVPN under 1.0.5 and then upgraded to 1.0.6, the issue did not resurface. So I'd say there is a pretty strong connection linking the DNS issue to having OpenVPN be enabled on 1.0.6 and something loading at boot-time which triggers this issue.
