Apr 23, 2022Guru - Experienced User
New - RAX200 Firmware Version 1.0.6.138 Released
New Features and Enhancements:
Adds support to EU SKU for Router Analytic (RA) opt-in, opt-out feature
Removes support from China SKU for gaming VPN Funjsq
Security Fixes:
Fixes sec...
Jun 07, 2022Guru - Experienced User
Sorry NG doesn't post if and when new FW updates are forth coming. We don't get that kind of information.
EdCzar
Jun 07, 2022Star
Would it be OK to begin a discussion of other routers (perhaps for other companies) that provide this functionality? There is only so long we can wait for a fix that may never happen.
- FURRYe38Jun 07, 2022Guru - Experienced User
User can contact NG support to express there concerns of there router problems so NG knows what your experiencing.
- cooleye63Jun 25, 2022Aspirant
Has anyone else had stability issues with a RAX200 using the latest firm 1.0.6.138 and resolved it? I had to reboot my router multiple times a day with this latest revision. Falling back to V1.0.5.132 and disabling auto updates fixed it immediately - not a single reboot since falling back.
I tried for several days to troubleshoot but there was never any meaningful symptom or hint of root cause other than download throughput would go to a tenth of its usual or stop working all together. Rebooting the router would clear the problem every time. It's an all NETGEAR ecosystem with the RAX200, EAX80 extender and CM2000 modem. Bypassing the extender made no difference.
- DarrenMJun 29, 2022Sr. NETGEAR Moderator
You may try backing up your router settings update to the latest firmware and then for a factory reset. https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router
