Apr 23, 2022Guru - Experienced User
New - RAX200 Firmware Version 1.0.6.138 Released
New Features and Enhancements:
Adds support to EU SKU for Router Analytic (RA) opt-in, opt-out feature
Removes support from China SKU for gaming VPN Funjsq
Security Fixes:
Fixes sec...
RikiRu
Jun 30, 2022Tutor
Your suggestion is the fix my network with my ISP when it doesnt work with 138 version of a firmware for the router, but it works with 132. And you are a Guru? lmao
As ive said, downgrading the firmware solves the issues, if that doesnt tell you there is something wrong in the 138 firmware i dont know.
Do you honestly think my ISP will help me when i explain this issue? they will tell me to fix my router, if they do anything they will debit me for their time, becouse the issue is at no level at their end.
I hope you also understand that the normal setup in a house or apartment is to receive or have a converter from Fiber or Koaxial connection today with built in Router function, im pretty sure 90 % of all modern houses and apartments are setup in this way, and to ask to contact an ISP for setup on DMZ betwen my home router and my convertion box when so many people have issues with the 138 verison is mad.
Also, you asked if a reset was made since last FW update, if you read, i wrote: "I have tried reseting my router", that has been done from the 138 firmware, no luck, i dont need to reset form the 132, becouse everything in functional in the 132 version of the firmware.
Stop protecting an obvious issue in the Firmware, I paid a premium for this Router to NOT have these issues, im sick and tired of people telling me that i need to diagnose my network when i have done NOTHING / NO CHANGE and it suddenly stops working after a Firmware update.
As i said, the DNS 1 server becomes the routers IP, 10.0.0.1 in my case, if i set static settings with googles DNS it starts working.
Just fix it.
EdCzar
Jun 30, 2022Star
Netgear has not yet admitted they have many serious problems with this update and it is still up there for other poor people to download and have problems with.
- Crash83KJun 30, 2022GuideThis was quite an expensive router which is not at all that old. I bought mine about a year ago. I'm pretty certain Netgear doesn't expect us to buy a new $500 router every year to get support. But it sure looks like they don't care if we start writing negative reviews for their most expensive home products.
This is absolutely ridiculous. My choice is to disable necessary functionality to make my router secure, or downgrade my firmware to use the necessary functionality.
Netgear, you need to solve this or you need to refund my money for my router. Considering I have been buying Netgear appliances only for years, this is the last straw.
