May 14, 2022Guru - Experienced User
New - RAX20/38v2 Firmware Version 1.0.11.112 Released
Bug Fixes
Fixes the issue where Advanced Tab cannot function when using Safari Browser.
Fixes the issue where QoS priority setting cannot be saved after enable QoS.
Fixes the issue where DHCP...
Retired_Member
May 21, 2022I forgot to follow up my post a few days ago to say that the Firmware is now showing and it installed ok.
The CPU info is now working in this firmware so i now have nothing to moan about.
đ
- FURRYe38May 26, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
