Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
rcl_3
Nov 10, 2022Aspirant
Similar to others, this auto-update caused my SSID and password to revert to factory defaults. I was able to access sites pretty consistently via Ethernet, but www access via WiFi was intermittent. I had to roll back to firmware V1.0.11.112_2.0.77 and also perform a factory reset afterward in order to make WiFi stable again. The firmware rollback alone didn't fix the issue.
- FURRYe38Nov 10, 2022Guru - Experienced User
Has a factory reset and setup from scratch this FW update? I recommend giving a reset and setup from scratch WITHOUT loading any saved backup configurations from file a try. And also mentioned this this post thread as well. Needs to checked before we can rule this a FW issue.
