Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
Anonymous
Nov 16, 2022The real problem was wi-fi connectivty stopped working on both the 2.4Ghz and 5Ghz channels. It would only stay connected for 3-4 minutes and then die. I would have to reset router, and then it would die again in another 3-4 minutes. This kept happening and I couldn't fix it.
This is what my experience has been since last night. Reverting to 1.0.11.112 at the moment.
Nov 16, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- AnonymousNov 16, 2022
Yes, been doing this for a while. That is the first step. I even factory reset the Cable Modem.
Yes. Refer to post above.
It is likely that the new FW does not come through via Nighthawk app or the Router UI because end users are testing it. Will hard pass on that. I spent quite a long time testing RAX40 in 2020 before they sent me a new RAX43.
