Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
Has a factory reset and setup from scratch been performed since last FW update? I recommend giving a reset and setup from scratch WITHOUT loading any saved backup configurations from file a try. And also mentioned this this post thread as well. Needs to checked before we can rule this a FW issue.
Also need to know how your wireless Basic and Advanced Settings are configured or had been configured. Possible maybe some changes in newer FW that could cause older configurations not to work right. Why a reset and setup from scratch is needed to check this.
mangotango wrote:
This new firmware completely screwed up my RAX43. It started with a reset of all my SSIDs, but I just renamed them.
The real problem was wi-fi connectivty stopped working on both the 2.4Ghz and 5Ghz channels. It would only stay connected for 3-4 minutes and then die. I would have to reset router, and then it would die again in another 3-4 minutes. This kept happening and I couldn't fix it.
I finally reverted firmware back to an older version and everything is working just fine now.
I have never had any issues with my RAX43 until today, when I got this new 1.0.12.120 firmware. It has some real problems.
Anonymous
Nov 16, 2022Has a factory reset and setup from scratch been performed since last FW update?
Yes. About four times.
Yes, exactly, I rebuilt my configuration.
Nothing special but I use 1800 Mbps with channel 161 on 5Ghz and Auto channel up to 2.4 GHz. Must have One Wifi identifier via Smart Connect so I use same SSID for both 2.4 and 5 GHz. And no, unfortunately, I cannot revert to test or troubleshoot, I have too many devices. Older FW worked fine with this config. I also use short preamble, I have a USB drive for readyshare, DNS are Cloudflare, and do not utilize QoS, I use OFDMA and all related AX features, that is about it.
My thought as well, but similar to other complaints, Wifi connection is not consistent, devices remain connected to the router but there is no internet connection. I eliminated my EAX20 extenders from the setup and still the same problem.
Just reverted back to 1.0.11.112 and reconfiguring the setup again. I also noticed that the new FW's UI is relatively slow compared to how .112 was.
- FURRYe38Nov 16, 2022Guru - Experienced User
Ok, thanks for the details. Will pass this on to NG for review. They are already aware of the auto update issue seen and seem to have disabled this v.120 from being auto updated on users units. So I guess for now, use v.112. Hopefully NG will fix all this.
- PaulGoNov 23, 2022Luminary
This is the third time this has happened. The two previous times I exchanged the router. It appears on some rare instances when making changes to the Wi-Fi settings the NVRAM setting become corrupted greatly slowing down Wi-Fi speeds. First I tried reloading the config file and then I tried re-installing the firmware. Both were unsuccessful. As a last measure I did a factory reset which put the NVRAM back into its original state and that worked.
- FURRYe38Nov 23, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
