Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
Retired_Member
Dec 14, 2022After initially 1.0.12.120_2.0.83 didn't work for me, I had returned to 1.0.11.112 for my RAX43 (which RAX54S uses) and the network in my home was solid for a couple of weeks. I had left auto-update function on and today it must have somehow pushed 1.0.12.120_2.0.83 again and my wife lost connectivity during work and our handheld devices and phones were posting three times slower wifi speeds while our AppleTVs could not even connect.
So just reporting that 1.0.12.120_2.0.83 is still not functional for RAX43 routers. I used to test and submit logs for Netgear for better firmware but I can't do that anymore as my wife works from home and can't mess with the network as much.
PaulGo
Dec 14, 2022Luminary
Bushmaster78FS - Did just going back to the previous firmware resolve the problem? For me it was a lot more difficult. I had to go back to the previous firmware (that did not help) do a reset (that did not help). I could not load the config file I saved since it was for the newer firmware and was not compatible with the older firmware. I the put the newer firmware back (that did not help). Finally what worked was loading the saved config file which I saved and that restored my Wi-Fi speeds. So far it is working but I am not changing any settings since that seems to trigger the WI-Fi slowdown.
- Retired_MemberDec 19, 2022
PaulGo wrote:Bushmaster78FS - Did just going back to the previous firmware resolve the problem? For me it was a lot more difficult. I had to go back to the previous firmware (that did not help) do a reset (that did not help). I could not load the config file I saved since it was for the newer firmware and was not compatible with the older firmware. I the put the newer firmware back (that did not help). Finally what worked was loading the saved config file which I saved and that restored my Wi-Fi speeds. So far it is working but I am not changing any settings since that seems to trigger the WI-Fi slowdown.
It indeed worked for me; I went back to 1.0.11.112_2.0.77 via a manual upload on the Admin/Router Update page. Once it successfully uploaded that, I selected "Revert to factory default settings" under Admin/Backup Settings and re-configured the router. So far so good.
- PaulGoDec 19, 2022Luminary
After Comcast had a lengthy service interruption I had to reboot the cable modem and then the router. The problem with the slow Wi-Fi speed happened again and this time I could not recover. I was able to return the router and instead I went to
Costco and got the RAX54S. Netgear has not yeat released the updated formeare for this router but it uses the same firmware number and usually release date as the RAX50. - Retired_MemberDec 19, 2022
PaulGo wrote:After Comcast had a lengthy service interruption I had to reboot the cable modem and then the router. The problem with the slow Wi-Fi speed happened again and this time I could not recover. I was able to return the router and instead I went to
Costco and got the RAX54S. Netgear has not yeat released the updated formeare for this router but it uses the same firmware number and usually release date as the RAX50.RAX54S is currently using the previous firmware for the RAX43. (1.0.11.112)
