Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
keith7777
Dec 21, 2022Aspirant
Did you just revert to the old firmware and revert then factory reset? I just reverted but didn't factory reset yet.
PaulGo
Dec 21, 2022Luminary
Yes, first I tried a factory reset on the new version - did not work. Then I went back to the older version and another dfactory reset - did not work. Then I went back to the new version - did not work. Then I loaded my confg file from the new versio which previously workedbut not longer resored my Wi-Fi speed. Then I gave up!
