Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
Jan 27, 2023Guru - Experienced User
What happens if you install a laptop fan cooler under the router?
What is the CPU usage % seen on the routers ip address/debug.htm page?
alsina86
Jan 27, 2023Aspirant
great idea, i'll try it
- GregoirecJan 31, 2023Tutor
Just wanted to chime in to also notify that my RAX50 with firmware 1.0.12.120 is losing current settings after every restart / power off.
I also noted that if I download current settings in a cfg file, the file contains the same old settings the router would revert to after a reboot, not the current settings.
- FURRYe38Jan 31, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
