Nov 09, 2022Guru - Experienced User
New - RAX35/38/40/42/43/45/50 Firmware Version 1.0.12.120 Released
New Features: 11/09/2022
Support Japan MAP-E and DS-Lite IPv6 feature
Support manually configure DNS sever option when SPC enabled.
Bug Fixes:
Fixes the issue where IPv6 DHPC r...
TC_in_Montana
Apr 06, 2023Virtuoso
I pulled my RAX50 (V1) out of the closet this morning, unplugged my RBRE960, and put the RAX50V1 online and configured it. The RAX50 is using the 1.0.12.120 firmware as noted by james55408
I am able to recreate the issue that he is reporting. It appears to be an Access Control Screen Display issue only affecting the 5GHz Guest Network SSID.
If I connect to the 2.4GHz Guest Network SSID and go to the Access Control Screen, the device shows as connected to the 2.4GHz Guest Network. However, the same device, when connected to the 5GHz Guest Network shows connected to 5GHz SSID, not the 5GHz GUEST Network SSID.
Note that the connection shows correctly (either 2.4GHz Guest Network or 5GHz Guest Network) in the attached devices screen - it is only in the access control screen it is appearing incorrectly.
Note also that I tested with "Allow Guests to See Each Other" enabled and disabled with the same results.
Apr 06, 2023Guru - Experienced User
Thank you TC_in_Montana for checking this.
Quick question, while your devices were connected to the GN, what was the IP address seen on these devices?
- TC_in_MontanaApr 06, 2023Virtuoso
Quick question, while your devices were connected to the GN, what was the IP address seen on these devices?In all cases (whether allow my devices to be seen is enabled/disabled), the IPs obtained by Guest Network devices were in the same 192.168.1.x range as my regular network devices (they did not receive 192.168.2.x IP addresses).
- FURRYe38Apr 06, 2023Guru - Experienced User
Thank you for this info.
