May 25, 2023Guru - Experienced User
New - RAX35/38/40/42/43/45/50/54 Firmware Version 1.0.15.128 - Hot Fix Released
New Features: 05/24/2023
Support Speedtest server selection in web GUI.
Support Unicode character for attached device name and router name.
Bug Fixes:
Fixes the issue where USB stick ca...
Twitchrot
May 26, 2023Star
Downloaded and installed for a RAX43. Initially left the config the same and did nothing else but the upgrade. WIFI immediately began to misbehave and the RAX43 became unstable. Approx every 5-10 mins WIFI on both bands 2Ghz and 5Ghz would disconnect effecting multiple devices (iPhone, iMac, Windows 11 PC). Seems the WIFI will not maintain a stable connection.
Advice is to make sure you have plenty of time to play with this version as quite possibly a complete reconfigure will be required. That is a shame considering it's only a firmware upgrade.
When time permits, will do a complete reset and reconfigure to see if the results are different and provide further feedback. In the meantime, rolled back to a known good working FW which caused a factory reset so make sure you have an old config backup handy, just in case.
Looking forward to seeing others experiences.
May 26, 2023Guru - Experienced User
It is recommended that if you do encounter problems after a FW update, that a Factory reset maybe needed. Set up from scratch WITHOUT loading a saved configuration from backup file. Older configs may not be compatible with newer versions of FW.
Good Luck.
