Dec 05, 2023Guru - Experienced User
New - RAX41/42/43/50/54 V2 Firmware Version 1.1.4.28 Released
Bug Fixes: 11/21/2023
Fixes the issue where default time zone is in wrong setting when internet access is not available.
Fixes the issue where offline client devices will show on current connec...
- Feb 14, 2024
Known Issues:
For users seeing a Access Denied message after the FW is loaded and processed by the router, users will need to press the reset button in back for 10 seconds then release. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Walk thru the setup wizard with a wired PC and web browser at 192.168.1.1 resolves this issue.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Do NOT load a backup configuration file. Access to routers web page returns. Then go back in and make a new backup configuration to file after the router is set up from scratch.
I also saw this issue with my RAX50v2 after updating to v.28 FW. A factory reset and walk thru the Setup wizard solved it and I got access to the WEB UI on the router using MS Edge. Users can revert to prior working version of FW as well.
If this fails for you, then you'll need to contact NG support and have them help you out.
Um, was this version of FW seen but the routers Auto Update feature?
Far as I know and can find, this new version is ONLY for the RAX50v2 model. I looked and didn't see anything for all other v2 model RAXs. Just the 50 series.
PaulGo
Dec 05, 2023Luminary
I In the past the RAX50v2 and the RAX54v2 firmware has been interchangeable. I have received beta firmware to help me and Comcast resolve and IPv6 issue that was labeled RAX50v2. Anyway it seems to be working fine with the additional benefit of increasing my Wi-Fi speed. Near the router before the update my speed was in the mid 600Mbps and now it is in the mid 800Mbps. My wired speed can go up to 940Mbps.
- FURRYe38Dec 05, 2023Guru - Experienced User
Ok, just checking.
Thanks for the feedback.
Enjoy. - michaelkenwardDec 05, 2023Guru - Experienced User
Netgear's firmware update system has its defect, but it usually protects people from trying to apply the wrong firmware to a device.
If it see something it does not like and that might cause damage – such as V2 firmware being written to V1 hardware – it usually throws up its hands, complains that it is the wrong version and refuses to proceed.
- PaulGoDec 05, 2023Luminary
So far no problems with this update. Netgear firmware always checks the router and if it is not compatible is will not allow it to be installed.
