Dec 05, 2023Guru - Experienced User
New - RAX41/42/43/50/54 V2 Firmware Version 1.1.4.28 Released
Bug Fixes: 11/21/2023
Fixes the issue where default time zone is in wrong setting when internet access is not available.
Fixes the issue where offline client devices will show on current connec...
- Feb 14, 2024
Known Issues:
For users seeing a Access Denied message after the FW is loaded and processed by the router, users will need to press the reset button in back for 10 seconds then release. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Walk thru the setup wizard with a wired PC and web browser at 192.168.1.1 resolves this issue.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Do NOT load a backup configuration file. Access to routers web page returns. Then go back in and make a new backup configuration to file after the router is set up from scratch.
I also saw this issue with my RAX50v2 after updating to v.28 FW. A factory reset and walk thru the Setup wizard solved it and I got access to the WEB UI on the router using MS Edge. Users can revert to prior working version of FW as well.
If this fails for you, then you'll need to contact NG support and have them help you out.
JoseTv
Feb 10, 2024Aspirant
I updated the firmware today (10Feb24) and I can no longer log into the router from any of my computers. However, I can access it through the Nighthawk app. I am getting the same error. It was fine in the previous version.
I don't want to go back to factory mode, there is an alternative to revert the version but I can't enter.
Thanks.
1modulator
Feb 10, 2024Guide
I found if you disconnect the modem you can login with no internet connection. Then simply go to the support download page and manually update back to 1.1.3.18. I have no idea why this is happening and have tried everything under the sun factory restarting router and modem in different orders to no avail. I cannot login via PC nor app. There is a new feature being added under Advanced, Security called Protection Engine and have tried disabling it but still no workie. I'm running the updated firmware now and just disconnect if management is needed which isn't very often but pisses everyone in the house off ; ) Hope someone realizes what is wrong and they release a hotfix soon. Good Luck
