May 11, 2022Guru - Experienced User
New - RAX42/43/45/50 Firmware Version 1.0.11.112 Released
Bug Fixes: 05/09/2022
Fixes the issue where Advanced Tab cannot function when using Safari Browser
Fixes the issue where QoS priority setting cannot be saved after enable QoS.
Fixes the issue...
Twitchrot
May 13, 2022Star
Can confirm 100% that the Safari issue and viewing the advanced tab has now been resolved. Many thanks.
- FURRYe38May 13, 2022Guru - Experienced User
Enjoy. 📡
