May 11, 2022Guru - Experienced User
New - RAX42/43/45/50 Firmware Version 1.0.11.112 Released
Bug Fixes: 05/09/2022
Fixes the issue where Advanced Tab cannot function when using Safari Browser
Fixes the issue where QoS priority setting cannot be saved after enable QoS.
Fixes the issue...
dmitch77
May 15, 2022Star
1.0.11.112 also fixes the Advanced Tab bug for RAX50. My router auto-updated a few days ago and all is well.
- PaulGoJun 17, 2022Luminary
I have the RAX45 but this seems to be a bug in many Netgear routers. Comcast in some ares has implemented vCMTS. After an hour or two IPv6 is lost. I have been working with Comcast and Netgear on this issue and after nine months of sending me test builds and finally Netgear tested their own setup with the help of Comcast. Then I was sent a test build and it resolved the problem. It should be released for my router and similar routers by September. Hopefully this fix will be released for all Netgear routers.
