FURRYe38's avatar
Apr 06, 2022
New - RAX45 Firmware Version 1.0.10.110 Released
Security Fixes: 03/15/2022
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https://www.netgear.com/support/product/rax45.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To find your router’s user manual, visit https://www.netgear.com/support/product/RAX45.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
  • Wireless AX Router Nighthawk (WiFi 6)
Let us know how it works for you...
No RepliesBe the first to reply
