FURRYe38's avatar
New - RAX70/78 Firmware Version 1.0.14.134 Released
Enhancements: 02/27/2023
  • Upgrades Armor agent to version 2.2.184.
  • Upgrades the data access layer (DAL) to version 1.3.67.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
  • Fixes the issue where the device icon is incorrect on the Armor portal.
  • Fixes the issue where a device priority cannot be detected correctly in the attached device list.
  • Fixes the issue where the DHCP server information is incorrect when the router is in AP mode.
  • Fixes the issue where email logs do not work with Hotmail.
  • Fixes the issue where access control is turned off after the router reboots.
  • Fixes the issue where the traffic meter start date and start time settings might become incorrect.
  • Fixes the issue where the Setup Wizard is interrupted after you re-enter the username and password.
  • Fixes the issue where Anywhere Access might not work.
  • Fixes multiple other minor bugs.
Firmware Update Instructions:
Download Links:
RAX70:
https://www.netgear.com/support/product/rax70.aspx#download
RAX78:
https://www.netgear.com/support/product/rax78.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX70.aspx#docs
Backup the routers configuration first:
Manually update FW on the router if this isn't seen on the routers web page: Recommended
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE:  A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
NOTE: Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
This article applies to:
Wireless AX Router Nighthawk (WiFi 6)
Let us know how it works for you...
