May 07, 2022Guru - Experienced User
New - RAX80 Firmware Version 1.0.6.138 Released
New Enhancements:
Removed Funjsq, for PR SKU
Security Issues:
Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/abou...
- May 23, 2022
Ok 5-23 I decided to have another go at 6.138 and this are my findings in my case:
did the upgrade and then factory reset, after that turn of and unplugged the router and modem and turn off PC
turn on following the procedure posted before and everything seem to be working fine until I activated the DDNS service and the VPN service, that's when it went back to could connect but no internet. I usually configured the VPN to access local network only but for some reason it blocks the whole router internet connectivity, configured to allow local network and internet and voila everything is working fine. another thin worth noting is that under Advanced- Security- schedule for some reason everything is selected to block connection for everyday 24hours I unchecked all of them and so far everything is working flawless
Ivan813
May 17, 2022Star
I updated my router May 13 to the new 6.138 but as soon as the update was done I lost all internet connectivity, devices could connect and talk to each other but not go to the internet, did a factory reset and it fixed the problem, today may 17 we lost power briefly and after starting again it went back to no internet connectivity did another factory reset and still the same is a pain having to configure everything again and again I end up reverting to 5.132
May 17, 2022Guru - Experienced User
OK, thanks for letting us know.
