May 07, 2022Guru - Experienced User
New - RAX80 Firmware Version 1.0.6.138 Released
New Enhancements:
Removed Funjsq, for PR SKU
Security Issues:
Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/abou...
- May 23, 2022
Ok 5-23 I decided to have another go at 6.138 and this are my findings in my case:
did the upgrade and then factory reset, after that turn of and unplugged the router and modem and turn off PC
turn on following the procedure posted before and everything seem to be working fine until I activated the DDNS service and the VPN service, that's when it went back to could connect but no internet. I usually configured the VPN to access local network only but for some reason it blocks the whole router internet connectivity, configured to allow local network and internet and voila everything is working fine. another thin worth noting is that under Advanced- Security- schedule for some reason everything is selected to block connection for everyday 24hours I unchecked all of them and so far everything is working flawless
WA4CUA
Jul 19, 2022Guide
My router reports this, but the firmware is not available today at the Netgear site; only 1.0.6.138.
I prefer to first download the update firmware from Netgear before updating my router.
I am hesitant to update my router via the Internet.
Firmware Update Assistant | |
| New firmware is found. Do you want to update the firmware? (Yes) (No) | |
| Current GUI Language Version: | 1.0.6.138_2.1.46.1 |
| New GUI Language Version: | 1.0.10.140_2.1.46.1 |
| Current Firmware Version | 1.0.6.138 |
| New Firmware Version | 1.0.10.140_1.0.79 |
| Release Notes: | |
| 1. [New Features ] Supports Japan IPv6 DS-Lite, MAP-E. | |
| 2. [Changes] Reduced unnecessary DDoS message printed at logs. | |
| 3. [Bug fixes] Fixed a bug where after enabling Open VPN function, DNS resolution function will become abnormal. | |
| 4. [Bug fixes]" Fixed a bug where basic dashboard page has an invalid link for PR SKU. | |
| 5. [Security Fixes] This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. |
Jul 20, 2022Guru - Experienced User
Looks like this was a new FW release:
Firmware Update AssistantNew firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.6.138_2.1.46.1 New GUI Language Version: 1.0.10.140_2.1.46.1 Current Firmware Version 1.0.6.138 New Firmware Version 1.0.10.140_1.0.79 Release Notes: 1. [New Features ] Supports Japan IPv6 DS-Lite, MAP-E. 2. [Changes] Reduced unnecessary DDoS message printed at logs. 3. [Bug fixes] Fixed a bug where after enabling Open VPN function, DNS resolution function will become abnormal. 4. [Bug fixes]" Fixed a bug where basic dashboard page has an invalid link for PR SKU. 5. [Security Fixes] This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
