Jul 20, 2022Guru - Experienced User
New - RAX80/RAX200 Firmware Version 1.0.10.140 Released
New Features and Enhancements: 7/20/22
Support Japan IPv6 DS-Lite, MAP-E.
Bug Fixes:
Reduced unnecessary DDoS message printed at logs.
Security Fixes:
Fixes security vulnerabiliti...
OK good to know. Keep us posted on that.
Ivan813
Jul 27, 2022Star
Ok, so far the onboard fan only turns on after a reboot which I had to do the last 3 mornings in a row. So finally did a factory reset and reconfigured everything from scratch again and now my phone could not stay connected to the 2.4 ghz band, had to turn of ofdma for the 2.4 band and the mu-mimo and it stay connected the other band was fine.
- FURRYe38Jul 27, 2022Guru - Experienced User
Thanks for the update. So I guess OFDMA and MIMO are effecting some phones when connected. Does the phone keep connected if MIMO is enabled only?
I recommend getting a laptop cooler under the router for added cooling:
Any laptop cooler can work.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router - Ivan813Jul 28, 2022StarTurn on mimo and the phone is staying connected and everything seems to be stable, just keeping ofdma off on the 2.4 for now. the cooler is on the mail thanks for the sugestion.
- FURRYe38Jul 29, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
