Jul 20, 2022Guru - Experienced User
New - RAX80/RAX200 Firmware Version 1.0.10.140 Released
New Features and Enhancements: 7/20/22
Support Japan IPv6 DS-Lite, MAP-E.
Bug Fixes:
Reduced unnecessary DDoS message printed at logs.
Security Fixes:
Fixes security vulnerabiliti...
UserRax200
Aug 28, 2022Aspirant
Since I updated the RAX200 to 10.0.10.14 the router keeps hanging Evey few days and becomes not responsive. That means not responding to nighthawk app and/or to its IP address.
Only workaround if power off/on the router using the physical back button.
I did factory reset also for nothing...
Aug 28, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the router feel extra warm or hot on top when this happens?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
UserRax200
