Jul 20, 2022Guru - Experienced User
New - RAX80/RAX200 Firmware Version 1.0.10.140 Released
New Features and Enhancements: 7/20/22
Support Japan IPv6 DS-Lite, MAP-E.
Bug Fixes:
Reduced unnecessary DDoS message printed at logs.
Security Fixes:
Fixes security vulnerabiliti...
Aug 28, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the router feel extra warm or hot on top when this happens?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
UserRax200
UserRax200
Aug 31, 2022Aspirant
Hello,
1) What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
AX7501-B0 Firmware Version: V5.15(ABWW.2)C0
2) Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
I have a very good quality CAT6 cable (Its shielded, etc...)
3) Does the router feel extra warm or hot on top when this happens?
Hm... I am not sure. I think its often warm on the top. I can't say if it was "that warm". I know the airflow intake is from below, its not blocked either.
4) Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Hm, I certainly rebooted both devices, not in the exact order you described,
I will try to follow the following instructions.
PS: I forget if I said that but before update to 10.0.10.140 I did not have that particular issue.
PS2: I'm in the hospital, more often than home. My wife reported me a few additional blocking, I also witnessed a few on my last outings.
- FURRYe38Aug 31, 2022Guru - Experienced User
Your ISP service device seems to have wifi and built in router already:
if this is correct...If so, This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupI would try option #2...
- UserRax200Sep 01, 2022Aspirant
Hi,
1) In Switzerland most ISP are not letting us bridge the ISP device. I checked if there weren't some adavanced hidden page to do that but there aren't any.
It's a 10G PON fiber line.
2) All modem/router from ISP wifi radio are off, and I only have 1 DHCP server on that network.
I haven't set the RAX200 in the DMZ though, it's a good idea.
3) I saw the AP mode but then I though it's a shame to not use that expensive RAX200 beside for wifi and RJ45 cat6...
I actually discussed at lenght my LAN there:
https://www.snbforums.com/threads/rax200-dns-configuration-guidance-needed.75985/
Note: it's a bit old, I managed to make it work since then...
Have to go, doctors coming.
Thanks for help
- FURRYe38Sep 01, 2022Guru - Experienced User
Hoping the DMZ will help on this then...
