Jul 20, 2022Guru - Experienced User
New - RAX80/RAX200 Firmware Version 1.0.10.140 Released
New Features and Enhancements: 7/20/22
Support Japan IPv6 DS-Lite, MAP-E.
Bug Fixes:
Reduced unnecessary DDoS message printed at logs.
Security Fixes:
Fixes security vulnerabiliti...
NoobZik
Nov 30, 2022Aspirant
Since I have updated to this firmware, everytime I am logging to web interface, I have updating settings for a few minutes. In the mean time, the router is cutting all devices connections until the updating settings is finished.
Any workaround/tips to prevent the updating settings upon log in?
- FURRYe38Nov 30, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- FURRYe38Dec 15, 2022Guru - Experienced User
Any progress on this?
