Jul 20, 2022Guru - Experienced User
New - RAX80/RAX200 Firmware Version 1.0.10.140 Released
New Features and Enhancements: 7/20/22
Support Japan IPv6 DS-Lite, MAP-E.
Bug Fixes:
Reduced unnecessary DDoS message printed at logs.
Security Fixes:
Fixes security vulnerabiliti...
pkaytes
Jul 02, 2024Guide
Its been a little over 2 years since the last release of fw for the RAX200. That seems like an awfully long period without updates. Has the RAX200 gone end-of-service?
- michaelkenwardJul 03, 2024Guru - Experienced User
Have you come across a problem that needs fixing?
Are you concerned about security issues?
NETGEAR Product Security | NETGEAR
Has the RAX200 gone end-of-service?- pkaytesJul 06, 2024Guide
There is a minor problem in how the "Logs" are displayed and emailed but its hardly worth mentioning.
I've been in IT for longer than I care to admit. I've had routers from many different vendors. With all of the security issues that are identified over time, I just find it peculiar that in the last 2 years, not a single one has been found with the RAX200. Ideally, thats the best outcome one would hope for but it seems rather unlikely. Just my opinion.
