May 05, 2022Guru - Experienced User
New - RAXE500 Firmware Version 1.0.10.82 Released
New Features:
Supports QoS
Supports Smart Parental Control (SPC)
Supports WPA2/WPA3 mixed mode
Security Fixes:
Fixes security vulnerabilities.
For more information about secu...
Tonkinite
Jun 29, 2022Luminary
After updating to this firmware and enabling WPA2/WPA3 mixed mode, I was surprised that several mobile devices started to complain that my network was hidden, despite SSID Broadcast being enabled on all bands. On performing a WiFi scan, I found that the Guest networks were up and running in hidden mode despite never being enabled. On a hunch I initialized all the Guest networks with non default values, left them disabled, and restarted. The primary SSIDs were no longer hidden and the guest SSIDs were no longer present. Weird.
There still seems to be no obvious means to set the DHCP lease interval, packet tracing on previous builds suggest those builds were using a default value equivalent to 24 hours. I suspect this is still the case with this build. A 24 hour lease time is a fine default for a commercial environment, but Apple and Google both recommend a default of 8 hours for non commercial use. If anyone knows of a means to either view or change the lease interval, that'd be appreciated. A too long lease interval can result in a DHCP request being refused, resulting in a device not receiving an IP address. This might not be an issue in environments with a few handfuls of devices, but is a significant issue in setups with many dozens of devices.
Many of the help screens are still quite incomplete, in Basic and Advanced web admin modes.
Jun 29, 2022Guru - Experienced User
Did you factory reset and setup the router after you applied this version of FW?
Screen captures of what your seeing would be helpful.
What Browser are you using?
- TonkiniteJun 29, 2022Luminary
No, I didn’t factory reset the router before this issue. Does the router factory reset itself when it auto updates it’s own firmware? I can’t recall any instances where factory reseting resolved issues like this, and I’ve owned Netgear routers for over five years.
I took very few screenshots of the problem while it was happening, I suspect that it is related to the guest networks being in default state. I’m just reporting the issue in case someone else has something similar happen. I did take a few showing the hidden network warning on iOS.
I used the Safari browser on macOS Monterey, I hope Netgear QA is testing browsers other that Edge or Chrome. I’m not sure how that’s relevant in this instance.
- FURRYe38Jun 29, 2022Guru - Experienced User
I would try a reset and also try Firefox or Opera browser on Mac.
I'll check this as well with mine. Also use Monterey as well.
- TonkiniteJun 30, 2022Luminary
If the original issue with SSID broadcast reoccurs, other weirdness, or signs of instability occur, I’ll reset the router. Setting values for the guest networks resolved the problem, they were greyed out defaults previously.
Right now, I’m more interested in the DHCP lease time issue, older Netgear routers such as the R9000 and similar ones have the ability to set lease time, but RAX series ones don’t. It’s an odd omission.
