Jul 20, 2022Guru - Experienced User
New - RAXE500 Firmware Version 1.0.10.86 Released
New Features: 7/12/22
Supports SpeedTest sever manual select list
Supports HK, UAE Wi-Fi country options
Security Fixes:
Fixes security vulnerabilities.
For more information about s...
p0se1d0nX
Jul 22, 2022Star
How come Netgear’s last couple of firmware updates for the RAXE500 (including this one) are NOT being pushed via the automatic fw update feature either on the Nighthawk app or through the gui login page?
Instead it now needs to be updated manually by the user. Did I miss something that NG has changed regarding fw updates?
Jul 22, 2022Guru - Experienced User
Some FW updates may not come down via AU. Also if you have AU disabled, you may not see it.
NG maybe scaling back some AU processes as we've seen historically that AU has causes problems. So it's recommended that users, IF you wanna update, manually update FW. Again, this is keeping with letting users have some control over there router systems and dealing with FW updates.
- p0se1d0nXJul 22, 2022Star
Is the consensus to update to this latest firmware or is it buggy and advisable to stay on the last fw release?
Also is it recommended to have AU enabled or best to update firmware MANUALLY?
