Jul 20, 2022Guru - Experienced User
New - RAXE500 Firmware Version 1.0.10.86 Released
New Features: 7/12/22
Supports SpeedTest sever manual select list
Supports HK, UAE Wi-Fi country options
Security Fixes:
Fixes security vulnerabilities.
For more information about s...
Jul 22, 2022Guru - Experienced User
Some FW updates may not come down via AU. Also if you have AU disabled, you may not see it.
NG maybe scaling back some AU processes as we've seen historically that AU has causes problems. So it's recommended that users, IF you wanna update, manually update FW. Again, this is keeping with letting users have some control over there router systems and dealing with FW updates.
p0se1d0nX
Jul 22, 2022Star
Is the consensus to update to this latest firmware or is it buggy and advisable to stay on the last fw release?
Also is it recommended to have AU enabled or best to update firmware MANUALLY?
