Jul 20, 2022Guru - Experienced User
New - RAXE500 Firmware Version 1.0.10.86 Released
New Features: 7/12/22
Supports SpeedTest sever manual select list
Supports HK, UAE Wi-Fi country options
Security Fixes:
Fixes security vulnerabilities.
For more information about s...
Aug 17, 2022Guru - Experienced User
Something to try on 5Ghz as well.
Tonkinite
Aug 17, 2022Luminary
Are you suggesting that those changes will help with the 5 GHz channel width spontaneously changing from 160 to 80?
What practical effect would this have, and what would be the likely downsides?
From the WiFi Recommendations:
Channel width
Set to 20MHz for the 2.4GHz band
Set to Auto or all widths (20MHz, 40MHz, 80MHz) for the 5GHz band
- FURRYe38Aug 17, 2022Guru - Experienced User
Just troubleshooting suggestions to see if any thing changes in behavior is all.
