Nov 05, 2021Guru - Experienced User
New - RAXE500 Firmware Version 1.0.8.70 Released
Bug Fixes:
Improves stability
Fixes the issue where the access control list (ACL) feature does not work properly
Security Fixes:
Fixes security vulnerabilities.
For more informatio...
AnteresStar
Nov 07, 2021Aspirant
Hi I have a RAXE500 with the beta driver Firmware Version V1.0.7.69_2.0.35_accessCtrl. Will I loose functionality if I upgrade to RAXE500 Firmware Version 1.0.8.70?
Nov 07, 2021Guru - Experienced User
I wouldn't think so. I'd make a back up configuration to file prior to upgrading. Load up the new FW using a wired PC and web browser. After the router is back to ready, power the ISP modem and the router OFF for 1 full minute or longer then back ON. Check operation.
