Nov 05, 2021Guru - Experienced User
New - RAXE500 Firmware Version 1.0.8.70 Released
Bug Fixes:
Improves stability
Fixes the issue where the access control list (ACL) feature does not work properly
Security Fixes:
Fixes security vulnerabilities.
For more informatio...
AnteresStar
Nov 07, 2021Aspirant
Hi I have a RAXE500 with the beta driver Firmware Version V1.0.7.69_2.0.35_accessCtrl. Will I loose functionality if I upgrade to RAXE500 Firmware Version 1.0.8.70?
tonydi
Nov 10, 2021Luminary
AnteresStar I also have a "special" beta FW that addressed a specific situation with some of my wifi devices. I've been told that the two or three FW updates that were released after my version do NOT have the fix that's in my beta FW so I'd lose that fix if I updated.
It looks like your beta software was built to address the missing AC list and if so, then this newest one could be the same. However, if your beta version also contained other fixes for problems you had, then maybe not.
As long as you still have the beta FW update file, I see no reason you couldn't install the new release. If it turns out that it breaks something then you could always just reinstall the beta FW.
