NYRugby
Jun 28, 2020Follower
New AX11000 with old AD7200 (X10)
Looking at replacing X10 with AX11000... I have an AT&T Gateway/Router, so the X10 is in AP mode and I use the Plex feature. Two items, if I replace the X10 with an AC11000 (also in AP), and I want to...
RajaDaja
Jul 02, 2020Luminary
NYRugby wrote:
Looking at replacing X10 with AX11000... I have an AT&T Gateway/Router, so the X10 is in AP mode and I use the Plex feature. Two items, if I replace the X10 with an AC11000 (also in AP), and I want to use the X10 as an AP, should I connect both to the gateway/modem or chain the X10 to the AX11000? If the X10 is daisy chained, will there be any issue using the Plex or attached drive (I’d think not, but while I’m here...)? Thanks- CH
I have my X10 in AP mode and it's hardwired to my RAX200. Bringing it all together is my Netgear CM-1000 cable modem.
