Redtulips7
Apr 03, 2019Luminary
New AX12[RAX120] Firmware Version 1.0.0.84
New Features and Enhancements:
Supports DFS channels and the 160 MHz mode for the United States.
Bug Fixes:
Fixes the router web interface issues that might occur when setting the Multi-G...
schumaku
Apr 06, 2019Guru - Experienced User
Redtulips7 wrote:
I ran speed test in the same Room that AX12 located 6 Feet away with Note 9
Have a local high-performance test system on your LAN, using a fast USB 3.0 SSD, ... ?
What difference were discovered to the R9000 (on 5 GHz 802.11ac, not .11ad!)?
Redtulips7
Apr 06, 2019Luminary
I have Core i9 7900X OC TO 4.5Ghz with Sammy 970 Pro M2 SSD so LAN was never issue
