joe_wht's avatar
joe_wht
Luminary
Aug 16, 2022
New Fiber, required to use THEIR Modem/Router
I just had 1 gig Fiber Internet installed today. ( no voice ) Last month I bought a new Netgear Modem for the fiber, but the tech said I can only use my RAX200. Their Modem> Their Router (wifi off)...
  • FURRYe38's avatar
    You could disconnect the ISP router from the ONT. Power OFF The ONT and RAX. Connect the RAX to the ONT, power ON the ONT then power ON the RAX and see if it connects. Check the Basic tab or Advanced tab for internet status.
