Killhippie
Nov 25, 2022Prodigy
New Firmware for RAXE500 1.0.11.94 released
New Features: 11/25/2022
Adds the options for Japan.
Supports the WPA2+WPA3 mixed mode for a guest network.
Security Fixes:
Fixes security vulnerabilities.
Bug Fixes:
Fixes ...
Killhippie
Nov 25, 2022Prodigy
The lights still don't flicker for Wi-Fi but do on Ethernet as in the last version, straight upgrade with no factory reset, all appears to be working fine so far, but early days ...
Nov 25, 2022Guru - Experienced User
Updated mine. We'll see how it works.
Thanks for posting that it was updated
- KillhippieNov 25, 2022Prodigy
I just noticed it this morning and was thinking one would be along soon, I'm guessing the internet lights are not meant to flicker on Wi-Fi on this unit? Has this been reported to Netgear? I did a factory reset in the end, not really needed but I like to make sure, all working as it should so far, no overheating issues, never had any with RAX120 (v1) either but and that included up to 40C in the summer in the UK this year. Router runs cool but its winter here, as long as the router has a clear airflow around it it should be okay but if not follow the instructions if needed, no issues with standard DHCP pool either but everyone's mileage varies once again, all good advice if you run into issues.
