Killhippie
Nov 25, 2022Prodigy
New Firmware for RAXE500 1.0.11.94 released
New Features: 11/25/2022
Adds the options for Japan.
Supports the WPA2+WPA3 mixed mode for a guest network.
Security Fixes:
Fixes security vulnerabilities.
Bug Fixes:
Fixes ...
Nov 28, 2022Guru - Experienced User
Checking with NG on this:
Solid white - The WiFi radios is operating or enabled.
Blinking white - The router is sending or receiving WiFi traffic.
Off - The WiFi radios are off or disabled.
I've passed this on to NG for there review...
Killhippie
Nov 29, 2022Prodigy
Had a reply from Netgear about the RAXE500 wifi lights and network lights etc not flickering.
"Wi-Fi LED is the design instead of a bug. In the RAXE500, we connect the LED to GPIO pin which means the LED is controlled by SW not Wi-Fi chip. So its hard to do the blinking when traffic go though Wi-Fi interface."
Hope that helps people, its by design not a bug.
- FURRYe38Dec 08, 2022Guru - Experienced User
Confirmed:
" The Raxe500 lights do not blink when traffic is happening. They said they will update the user manual to reflect this"
- FURRYe38Dec 10, 2022Guru - Experienced User
So here is a first to date ever seeing 4800Mpbs connection rate between two devices. đČ
RAXE500 in wireless bridge mode connected to a RBKE960 on 6Ghz:
