christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
Retired_Member
Jun 12, 2020I am using Smart Connect and WPA2+WPA3 and it has been very stable since the release of the FW. The problem is FW rendered EAX20 extender unusable.
If you are using WPA3 only, switch back to WPA2 and give it a try.
christer12
Jun 13, 2020Star
Yes, I use Smart Connect and WPA2+WPA3, my galaxy S8+ don't support WPA3. Just a few new devices support WPA3. I belive I just need to be patient with RAX40. I know what I signet up for. Wifi 6 isn't quite finished
- Retired_MemberJun 13, 2020
I jinxed myself, we had some dropped multiplayer connections on Nintendo Switch tonight. I feel like this router needs to be rebooted every so often.
- Christian_RJun 18, 2020NETGEAR Employee Retired
Hello Nighthawk AX Community,
For those experiencing issues with the latest firmware version on the RAX40, may you confirm if you've taken a moment to revert to the previous firmware version to see if the issue persists.
Thanks,Christian
- jrjdotmacJun 18, 2020Initiate
I reverted to the prior version and the intermittent disconnects are gone. Everything is fine with the prior version.
