christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
christer12
Jun 13, 2020Star
Yes, I use Smart Connect and WPA2+WPA3, my galaxy S8+ don't support WPA3. Just a few new devices support WPA3. I belive I just need to be patient with RAX40. I know what I signet up for. Wifi 6 isn't quite finished
Retired_Member
Jun 13, 2020I jinxed myself, we had some dropped multiplayer connections on Nintendo Switch tonight. I feel like this router needs to be rebooted every so often.
- Christian_RJun 18, 2020NETGEAR Employee Retired
Hello Nighthawk AX Community,
For those experiencing issues with the latest firmware version on the RAX40, may you confirm if you've taken a moment to revert to the previous firmware version to see if the issue persists.
Thanks,Christian
- jrjdotmacJun 18, 2020Initiate
I reverted to the prior version and the intermittent disconnects are gone. Everything is fine with the prior version.
- BshearanJun 26, 2020AspirantHow can you revert back to a previous firmware version?
- The_DavidJun 18, 2020Initiate
I downgraded back to .64 from the support site. It's only been a couple days, but so far all the problems are gone.
- Retired_MemberJun 18, 2020I reverted back to 64 and my EAX20 extender was able to connect to the RAX40 router. Other than my extender not connecting to the router therefore not extending the wifi with the new firmware , I dont have any significant issues.
